the fishing shack
Wood County Tx
couple more
see that white foam .... it leaves burns on uncoverd skin when you spray it.
sure made a mess but we are all sealed up now, no moisture, bugs, now comes the finish batts and some wall board
Wood County Tx
she pulled like it was an empty open trailer back there, wanted to go faster but i kept pulling the reins back, that engine really likes 2500-3000 rpm, it will flat pull.
it would slip down one gear on the hardest grades and just keep on keepin on, no smoke just go go go, passed several CTD equipped durdges pulling lesser trailers, which made me :D :D :D
zr1pete
Florida
Good Looking Setup
Hey Powerboatr, Got a love that set up, It's looks great.
I have a 2005 F-350 KingRanch CC Dually TowBoss with a Cedar Creek 34rlts.
Last time I weighed GCVW 23000 even. you gotta love the way that Ford pulls.
:thumbs
Wood County Tx
Pete
yep your pretty heavy as well. I need to go weigh the truck alone, I have added two huge tool boxes and they are FULL. I think i am in the 8500-9000 range just truck
but i am so impressed with the 430 gears and wide power band, this puppy just kept going, I ran with cruise on 80% of the run, till we hit the mountains here in north bama, then i let it pick a speed it liked going up.
one hill we dropped into 3rd and hit 45 mph at the top but it was a steep climb of 600 feet.
Ford did a good job with this gear combo and tranny programming, the downshifts are not jerky. they engage like everything is in unison,
:sweet :sweet .
the power at 2500 rpm is incredible,
i will quit gloating now:D
zr1pete
Florida
Powerboatr, I weighed my truck alone and it was 9020 with me in it.
Wood County Tx
was that just you and an empty truck with no boxes
OH S@@t that means
that i am probably closer to 10k with full fuel and my 230 pound tail sitting in it, no wonder she rides smooth
one of my concerns is I am very close to the front axle weight rating :(
haulin8or
Hotlanta, GA
WOW, you were not kidding about your pin weight in your other thread! You can see she is squatin' a little in the back. I am not too familier with 5th wheels, don't they have any kinda way to shift some of the weight back like on my bumper pulled trailer that has weight distribution bars?
Almost forgot, I love the 'shak'. That is sweet!
zr1pete
Florida
Power Boatr, Here's the numbers from the local flying J This is without the trailer:
Front axle: 5280
Rear Axle: 3740
GVWR 13000 now this is the rating of my truck, not the actual weight of the truck.
Truck is rated for:
Front axle : 6000
Rear axle : 9000
Now here the particulars,
Warn Winch 9500lbs w/ winch mount. stainless brush and grill guards full 125' 5/16 aircraft cable all bolted on the front frame.
aluminum tool box w/ assorted winching supplies chains, pull strap, pulley block. Two tool boxes ( never can carry enough tools) Two 20 ton hydraulic jacks, two way radio equipment and CB.
With the Trailer hooked up and ready to go, Full Fresh water food fuel and LP.
Front axle 5180
Rear axle 5980
Trailer 11850
GVW 23010
Brad1103
