mp18d
In Oct I put in a Dieselsite 203 stat and filter system. Worked great, felt stronger on the freeway and towing. Temp gauge showed appropriate numbers for the stat.
Couple weeks ago put in new waterpump, belt, pullys and hoses. No issues tho havent driven it much since, but still gauges were appropriate.
Today I am driving down to the Valley in the storm we're having- have to stop 3 different times for wrecks. Takes about 1-2hrs each time. I am getting cold sitting there listening to the radio so turn the heat up. Little help, look at the temp gauge and it is at zero. Like I just started it up. So is the trans temp. Ck fluid level, no leaks runs ok and as soon as we start moving she warms up again but only to about 180, cept going (creeping, CalTrans wasnt in to plowing today I guess..)downhill when temp dropped to about 150. Trans never did warm up past 130.
What the heck, is the thermostat stuck open or something else??? I've only experienced them sticking closed! If so Dieselsite may have some quality issues?!
Any other ideas??
Thanks
Mike
Any other ideas??
Thanks
Mike
