Spare Tire lock like wheel lock?
dpantazis
#12
under the cheddar curtain
hi all-
is there such a thing as a spare tire lock that locks the jack rod hole?
i had truck in the shop to put the snow tires on. i did not have time and considering the weather elected to have the goodyear do it. i asked them to look at the spare tire because i can not get it down.
they said that it has a lock on the jack hole, it takes a key like a wheel lock.
i tried searching online but could not find anything.
anyone seen one of these? sources?
thanks
dennis
yep.
About the size of your middle finger, kinda looks like a hubcap tool from Dad's Crown Vic...except it doesn't have the T-handle/screwdriver
Should be in a black/clear heavy plastic pouch that closes like a Zip-Loc bag.
Fits on the end of the jack crank
yep.
What JL said.
You can also take the black plastic tube off that the handle slides into, then take a BFH and knock the lock off and your jack handle will fit into the hole and you no longer have to worry about the spare tire cable lock.
yep.
X2.. mine was in the glovebox ?
