Yes sir, I twisted the 4x4 knob and it came off with a little effort. Then I really twisted the shifter knob and the rubber grip loosened and will spin (its still very snug, but I can spin it) but the cap piece that shows the shifting pattern stays put and does not move???
The stick holds to the rubber shaft at the floor sufficient enough for driving (it doesnt just fall off) but it does come off when you pull up on it. Nothing is broken, it appears as though the stick is meant to pressure fit over the rubber shaft at the floor and I simply pulled the thing free but Im pretty sure I can apply a little sealent to the rubber shaft and get the stick to go back to sticking tightly.
I still want to get the shift knob off though. I looked down the stick last night but it was dark and I couldnt see anything in there, Ill take another look at it today in the light.
