jeffnzoya
Left out Sunday for Edisto Island, SC with our 29 Foot FWT IN TOW.
As soon as I got started I noticed that the camper felt quite a bit heavier than I remembered it last. I was watching my boost guage and 19 psi for about a second was all I could get. I was expecting more with the heavy load. Not only was that it, but it felt like there was no throttle response and any little hill was noticed big time.
There is a good pull up the mountain on 26 out of Erwin, TN to Ashville, NC. and I noticed a lot of hiss from the DIY intake. It sounded a little different, so I pulled over to check it out and found the filter had blown off the connecting tube. I thought that I may have left the clamp loose so I give it a few extra turns. Back on the road and as soon as I had to get the boost up around 16 to 19 it blew off. I limped on to the camp ground.
Today, prior to the return trip, I took the chip out and reprogrammed my truck to stock. I wanted to see how it pulled stock and what kind of boost it would get. Since the chip has been in my truck since I purchased it I have never towed in stock setting.
AND I NEVER WILL AGAIN. No power at all!!! 14psi max boost and had to run WOT many times just to try and stay above 60 and keep out of the way of semi's that were blowing my doors off. Actually dropped to 2nd gear 4 times. Never done that before.
Although the filter did not blow off on the return trip, It did make alot of noise, and any time the turbo has to boost it hisses very loud. Has any body else had this problem with there DIY set up. I can't help but think this may be part of my boost problem.
Jeff.
Jeff.
