melmount
when replacing all 8 injectors, do you have topurge the system before you run it? How about if only doing one injector?
if so how?
if so how?
Once the engine spins and compresses with the starter it will throw the oil/fuel mix out at fairly high velocity, I would suggest pulling the glow plugs too to give you more space for the mix to exit.
The downside to this method is that if there is too much in the cylinder then you risk tweaking a connecting rod. By pulling the injectors front to back you help reduce this risk. Vacuum pumps are on the loan a tool program at autozone and a small hand held vac pump is very cheap insurance in my book. Here is one from autozone that is $30 and will do exactly what you need.
FWIW: I have a BD exhaust brake on my truck. Part of that system, is a larger HD vacume pump. I used a collection cup for bleeding brakes. I hooked up a line from the vacume pump to one fitting on the collection cup and ran a long skinny hose from the other fitting. That long skinny one I stuck thru the injector hole to do the "sucking"
