Right foot is causing excessive tire wear, and I know that at this rate I won't want to go through another Michigan winter on original rubber. Any recommendations on a taller/wider combination. At present, I believe the factor rubber is 275/65. I've added a 2" level to the front, so I'd like to fill the wheel openings a bit more. Thanks
