removing the dash?
clintusaf
Clint
Bossier City
Hey,
i just got some white face gauge overlays to match my A-pillar gauges.
Does anyone know how to expose the factory gauges to do this?:confused:
I'll be posting up the pics of the install when i'm done. Thanks!
rammertide07
Rogersvilles, AL
Found this on another site....
"The first thing you have to do is take the radio out. If you still have the Ford radio, you will need a set of radio removal tools or fabricate something on your own to get it out. Some claim they have used everything from coat hangers to nails. Anyhow, once the radio is out, there are two hex head screws (7mm or 10mm I believe) where the top of the radio was. After removing those two screws the dash just pops off. Pull firmly but gently starting at one corner and working your way around. Then all you have to do is unplug the wiring harnesses for the lights, etc... Good luck."
