removing quick disco fuel pump fittings
SprintRacer26
Wichita, KS
What type of fuel line do I need, where can I get the tool to remove the fittings, and do I just cut the line and hose clamp the new line in place?
Thanks.
Wood County Tx
I think its called a BEE GEE tool :roflmao :roflmao
:sorry
you can get the fuel line relaese tool at most any parts store for a couple buckaroos
need more details on what your doing.
roosterdiesel
Earl needs B100
Amarillo,TX
ThisWIKI Article covers removing the air leaking fuel line connections. Just replace with at least a 30R7 rated hose and clamps.
Like already asked, what are trying to accomplish?
SprintRacer26
Wichita, KS
I'm just wanting to get rid of the quick disco's that suck air in on both sides of the pump. Eventually I'll drop the tank and do the mods to it too.
BTW, what size of 30r7 fuel line do I need? 5/16", 1/4", 3/8"?
thanks.
roosterdiesel
Earl needs B100
Amarillo,TX
The pressure side of the pump isn't a problem since the connections are ok under pressure, it under vaccuum that they leak air.
I used 5/16ths hose.
When I switched evertying over to SS braid with JIC connections I used an elbow that 5/16ths compression to JIC adaptor. The shop accidentally sold me a 3/8ths one and it was too big.
