Question Rear window power slider sticks.....
jec2thdk
Boise, Idaho
Where is a diagram on the rear window slide mechanism. Mine tries to open but then doesn't---I know the motor is good----I think there's a cable that is possibly off track---any wizards out there?? How do I access the window mechanism??? Thanks for the help!!
zr1pete
Florida
I ran into this with my 2005 King Ranch, and ultimately had to have the back glass replaced because it's serviced as a unit (FORD) now what happens is the wire cable eats up the plastic inside and binds up so the cable can't move, and it can't move the window. There is no other fix for it I'm told.
HeavyAssault
King William, VA
You can try a dry film lube like a teflon spray as well. It will help the movement and not junk up with crud.
