Rear Spring Question
rsjohnsn
East Tennessee
Hi all, I have a question about my rear springs on my 04 F-350 CC Long Bed Dually 4x4. I had a broken spring a while back and I replaced both sides. After the springs were replaced the truck set level with the front as it always has. The problem I have is that they are on the overloads when I put a load on her. This is how the old springs were as well. My question is, how many springs should I have in a rear spring pack and how many should I have in a front pack? Also, what size block should I have as well. The reason I am asking is because I believe the previous owner has replaced the rear springs or removed a spring to haul his fifth wheel which is why she sets level empty. I replaced the springs with the same ones that were broken and if he changed them then this might be my problem. I believe this is why there was one broken. Oh yeah, I had to use the numbers that were on the srings as my truck doesn't have the little sticker on the door pillar that gives the spring codes. Can anyone pull this from the VIN #?
Thanks
Scott
