Rear main seal (special tool)
black_cloud_stroker00
GO BIG RED!!!
Bellevue, NE
I will changing my clutch soon. I plan on replacing the rear main seal at the same time. I have read other posts that talk about a special tool for this. any help would be appreciated.
94f450sd
certified nutjob
plymouth,ma
it usually comes with the seal.but for some reason the one i bought didnt come with the tool.there is a wear ring on the crankshaft that you need to remove also.i found that a dremel with a small cut off wheel works great.slice the ring with the dremel and tap it with a chisel,itll fall off.DO NOT seperate the ring from the new seal,it MUST be installed as a unit.the new seal will also come with a tube of the gray RTV from hell.they give you enough to do the pan and seal.when you buy the seal it will come with instructions.
RoyBoy
Diesel Dork
central WI
Rich, I always use a dull cold chisel and cut into the ring in a place or two (not going all the way through, this expands the sleeve, comes right off.
I would be afraid a cutting wheel on it could easily damage the crank surface, but maybe you're steadier than me. :D
94f450sd
certified nutjob
plymouth,ma
just gotta watch the depth as youre cutting.ive never had luck using a chisel on them.always screwed up the crank shafts
ford man
yes there is a special tool for the rear main seal, i bought one since i put a new torque convertor in my truck and decided since i had the transmission out to replace the seal, it was about 500 dollars for the kit.
