Question radiator leak
dunbar
Brighton, Colorado
I was using a 1/2 inch breaker bar on my tention pully to my serpintine belt, and when I took it off it slipped out of my hand. It fell and hit the fan blade, and bounced into the radiator putting a little hole into it. Has anyone used stop leak, or any other brand? Does it work long term or is it only for short term? Or should I just take it out and have it fixed?
02stroker
Gratz, Pennsylvania
Having it fixed or replaced is the right thing to do. I don't trust stop leak. To many other things it can plug besides the hole. Just my opinion. I know it's not the cheapest option, but the peace of mind might be worth it.
dunbar
Brighton, Colorado
Thanks, I know that is the right thing to do, so I will, I was just wondering. I pull a heavy trailer every weekend, and I do need ease of mind.
What Strokers sez, X2.. But if you ever need to do a temp fix (?), try to find & use.. "Barrs Stop Leak". Good stuff.
(I've always carried a can, for any On The Road emergencies) (Like a stone thru the grill ?)
dunbar
Brighton, Colorado
Thanks, I'll pick some up. Do you flush it out and fix the leak correctly as soon as you can?
Yes, like stroker sez: for the piece of mind, knowing the cooling system is up to snuff..... and if it's my yer Daily Driver..... And, you tow alot.
On Edit ? I guess you could say.. It's a "FIX", but not a "REPAIR" ??
