jvencius
At what point should I change the radiator hoses? When I hit 60K miles in about a month or so, I'll be doing a lot of maintenance to the truck and while everything is draining, I plan to install a 203* thermostat and a new T-stat housing. Since the radiator will be drained, I figure it'll be a fine time to change the hoses since winters up north here can't do them any good and they're over 4 years old now. Is that too soon to change them before they fail or should I wait before "fixing" a problem that doesn't exist (yet). When I do swap them out, do I re-use the stock clamps or is there a better clamp solution out there? If there is a better way of clamping the hose ends, please point me to a vendor so that I can get the parts in advance (BTW, powerstrokeshop.com is getting my order for the hoses, unless there is a dramatically better solution out there).
