any one use the hose clamp fitting on the pyro gauge to hook it up? you guys all doing the weld in? just checking? my gauge is coming I was unsure the best? easy??) way to do this?
thanks
yup PRE TURBO is the most accurate & the best reference point
when talking to others (since if nothing else thats where 99% of
folks install 'em anyway).
Ive run the probe both post turbo (in the down pipe using the
band clamp) and now PRE turbo in the manifold...the manifold
(pre turbo) is where you want it.
as for the filings...and greasing the bit/tap...it wont hurt...but
the majority of the filings will fall DOWN away from the
manifold anyway...AND they are very small / fine bits of cuttings...
i bet youll see more damage to the compressor wheel using
a "free flow" airfilter than you would from the filings.
Has some good pics of what he describes. I didn't worry about the shavings either. I tried to be careful when drilling and taping and some got in there, but doubt it hurt anything.
