Pulling 7.3 Engine
BWard
Auctioneer
Greeneville, TN
Anyone know if you can pull the engine and auto tranny at the same time??
I'm pulling the motor out of my totaled truck and my oil pan is hitting the cross member under the motor, ( I removed both motor mounts ) and the up pipes are hitting the firewall. I am thinking the the under motor cross member is pushed back alittle.
any help would be awesome.
Thanks,
Brian
yeah, but I don't think you can go up & over the core support..
you gotta remove the front clip..
Tbar
SDD STAFF/Moderator
Hot wrench the cross member......?
Tbar
RoyBoy
Diesel Dork
central WI
Did you remove the turbo? Also remove the transmission crossmember? Should come right out after that.
CSIPSD
Bend, OR
Needs to look like this... and the turbo needs to be pulled.
Pm_guru
