PSOM code needed
94f450sd
certified nutjob
plymouth,ma
anybody got the PSOM calibration code for my dually?it has 4.10 gears,235/85/16 tires on it.
Patrick Feeley
Tehachapi, CA
I have the same setup and I think I used 976 which seems be correct (based on the highway mile markers over a distance of over twenty miles ... its within a tenth of a mile over that distance). This was a code from a stock F350 4x4 (235 tires). This code was between the one I calculated using ten revolutions of the actual tires while on the truck and one using data from BF Goodrich (I'm running the KO's). The rear axle ratio does not enter into the calibration code on these trucks. Hope that helps! Cheers!
94f450sd
certified nutjob
plymouth,ma
ok i used the 796 code.but im not sure its right.in O/D at 50 MPH im turning 1500RPMs.i used 1/2 tank of fuel to go 60 miles:eek: does this sound right?
Patrick Feeley
Tehachapi, CA
Hopefully the 796 you stated is a typoand not what you input! The milage doesn't sound right and since I have a 5-speed, my RPMs will be around 2500 at 70 mph. After changing mine, I used the markers over 20 miles and the odometer agreed within 1/10 mile. Cheers!
Brad1103
