problem with cargo and interior light!!!
The Dude
langley b.c.
I need help! my door light stays on along with my cargo and interior light, I checked all my door switches there good! I looked for broken wires no such luck! any body have any thoughts!!!!
Turn down the interior dimmer. It is the small vertical thumb knob next to the light switch. You have it set to turn on the lights all of the time. Just back it down a little and you are good.
orion_134
Woodbridge, VA
Mine has also done this when the passenger door sensor was stuck or malfunctioning. I sprayed some WD40 into the hole that the sliding rod goes into (not sure what the name is) and it freed up the switch.
Jesse
The Dude
langley b.c.
it`s defenetly not the dimmer switch!! the open door light is on on the dash! iI had already lubed the switches when I had them out to check them! does anybody know were the gem module is??
