preventing rust
nascar_fan28
IL
hey, im having a problem with rust on the bottom of my doors.. is their a good way to keep dirt from going in there? i thought about rockerflares.com they have some rocker guards... but not sure how they would look. any ideas you guys have come up with?
Fine69
Cranberry Twp,PA
What part of the door are you having problems? In the seams, the doorjam? Or is the rust caused by stone chips?
nascar_fan28
IL
along the very bottom of the door.. right under that rubber strip. its pretty bad... and bottom of my tail gate too... rest of the truck ist good.. but these areas are bad. not sure what to do.
BIG DUTY
F-250 Care Taker
Traverse City, MI
i would sand/grind the area down. Spray on a rust converter and then roll on a coating such as hurculiner or por-15. All of these products can be found at a local auto parts. I use hurculiner on my lower tailgate about the bottom 2". It has lasted very well over the last year.
kingkevindavid
Middleboro, Ma
has to be perforated before they'll consider it.
If it was my truck I wouldn't have a problem finding a perforation. If that truck is a 2005 and it is already rusting, it must be a defect. I don't care where you live and how much salt they use that shouldn't happen. My Brothers truck is a 2000 that has been in Massachusetts since day one and sees more than its fair share of plowing and it has no rust. It might get washed once a year at a car wash.
I would be interested in seeing pictures of the rust.
no-red 6 0
Senioritis
southmetro MN
perforated - and by that do you mean 'holes'? :eek:
i too would like pix!
i have my own set of 'paint' issues.
the door piece has actually popped off and is now about the size of a quarter and is rusted rather well. ford body shop iirc wants over $500 to repaint/clear entire door and possible blend clear into rear door. :rant
the passenger door is doing the same thing as i tried to get them to do a 'warranty' paint job as i was going for a 'defective' paint job. no go.:rant
i now will have to go inspect MY tailgate and door bottoms.
hijack off.
carry on
nascar_fan28
IL
well.. my passenger door is nice and smooth and tail gate and drivers door are flaking bad... think i should take to dealer? and i think by perforated.. he means rusting all the way through the metal. which mine is all the way through.
kingkevindavid
Middleboro, Ma
I would try the dealer first, it is worth a shot. If it is rusted all the way through then I would complain pretty loudly about it especially if it is only 3-4 years old.
