Power Window
mjfco
Depoe Bay, Oregon
The rear window on my crew cab is not going up and down, dose anyone know how to get the motor out checked the voltage it is good, motor just clicks when the button is pushed. :thanks
Patrick Feeley
Tehachapi, CA
Remove the door panel. The are three bolts that hold the motor to the regulator assembly (which is riveted to the inner sheet metal). You can just see one of them through one of the holes in the inner skin. You'll need to drill access holes to get to them, but after that it'll come out easy. Cheers!
MUDWHISTLE
Diesel Lover
oregon
Not sure but I had a bud with the same problem and he just cleaned the contacts for the switches and got them to work again. just a thought to try.
Patrick Feeley
Tehachapi, CA
I had to tighten up the pin connections on the rear door switch on mine (figured that out after I took the motor out and bench tested it). Cheers!
