bears4x4
grease monkey
I know it sounds crazy but I have a i believe a 800O btu 115v 15 amp window unit and was wondering what size power inverter I would need to run this in my work van to fix the Ac it's around 700 and I have a window unit
To find the power requirement of your AC unit; amps X volts = watts, so 15 X 115 = 1725 watts. That is the running power required. The starting can be a lot higher, like 2200 watts to be safe. If you get a big enough inverter it will work, but it will kill a smaller inverter.
....Not to mention the Battery capability it would take for 2200 watt Starts, and then to Carry.. a 1725 watt load, for any length of time ?
I'm think'n GENERATOR. (could be used for other needs too ?)
Ok ok , next thought then, I have my work generator, 5500w running , now will that over heat in the van, and yes I would run the exhaust out side some how.
Ok ok so what I'm understanding in new Ac in van
