power inverter problem???
bears4x4
grease monkey
katy texas
im trying to install a power inverter 1200w 3000 surge in my 00 f350, i have run two 2ga wires from the battery to the cab below my stereo and have hooked it up to the inverter, when i test the cable for power with and with out the truck on it reads 13.bla bla bla volts, when i turn the inverter on the voltage that being pulled through goes down to 9.bla bla bla volts :rant , what can cause this:doh: any ideas and opinions to help me out, thanks:)
Northeast Texas
is the truck running when it shows 9 volts input ?
and is there load on the inverter during this 9 volt episode?
start teh truck and see if the voltage goes up
what is your load ratings on the inverter?
12 vlts and dc amps under load etc
Resistance causes voltage drops. Make sure you have clean connections where the cables are hooked to your power source. And to ground.
Zookie400
I WANNA GO FAST
wallingford, CT
my thoughts exactly...resistance (dirt, corrosion...) or a loose connection.
think of it as a kinked garden hose, it will have pressure until you spray it and it just trickles out.
your reading 13 volts, and when the inverter tries to pull a significant amount of amperage through the cables they cant keep up and the voltage
(pressure) drops.
bears4x4
grease monkey
katy texas
hey
thanks im working on it again tomorrow, the truck can be running or not and it does the same thing and im going to change my inverter ground from a 10 ga to a 4 ga wire and make a better ground contact:thumbs
