OK--here's my initial impressions:
-The WW doesnt' provide any really dramatic power/EGT differences. EGT's have dropped ~50-100 degrees while unloaded so that's a plus.
-The turbo spools faster and smoother and doesn't have any of the fluttering/turbo stall at 16-19 lbs of boost like before.
-Since I've only driven ~ 10 miles with the wheel in, it's much too early to make a guess at mpg increases.
-Installation took a little longer than I thought, but not really all that long. From pulling into the garage to heading out for a test drive (responding on a VFD call excluded), it took about 5 hours to do the install with the turbo on the truck. If I had to install another one, I could probably get 'er dun in ~ 4 hours, as long as the truck had a factory downpipe.
-Having a 4" downpipe made it a beyotch to get a padded screwdriver in the exhaust side of the turbo so that I could unscrew the old wheel from the shaft. There just wasn't enough room to easily move the pipe out of position to clear room into the exhaust side of the turbo.
-Unbolting and re-bolting the wastegate actuator in position was an absolute PITA, since I didn't unhook the c-clip connecting it to the wastegate. That'll come next week when I put a little more tension on the rod to build a little more boost.
-Having done the CCV mod made things easier, since I didn't have to deal with disconnecting and unbolting the CCV inlet.
-The sound isn't dramatically different from before, but it sounds GOOD. There's a bit more whistle at low-to-medium throttle, and when I let off the loud pedal, I can hear the turbo spinning down, and that's quite
More impressions to follow when I get more time behind the wheel.
