nox reading way high
bears4x4
grease monkey
katy texas
ok its about my wifes 92 carmaro, its a 305 i have replaced everything on it but the o2 sensor, would that effect this??
all electrical on motor, head, intake, throtle body gaskets etc, every thing but this "i did the top end"
high NOX on a gas engine is a function of combustion temperature
timing over-advanced (you did unplug the timing connector, right?)
thermostat too high of a temp,
egr malfunction (as in NOT)
'bout all I can think of at the moment..
Zookie400
I WANNA GO FAST
wallingford, CT
heat heat heat like JL said.
something is causing high combustion temps, lean mixture, egr system failure, t-stat.
cool it down in there, or cheat with alcohol!
bears4x4
grease monkey
katy texas
all new, map sen, egr.i put a 185-190 thermosat in it, factory said like 165, i was going for a lil warmer- better fuel milege, ill change it back any other ideas let me know
yeah.. lean mix... throw a fuel filter on it while you're at it.. does it have a good idle flare when you start it?
o2 sensor could be the culprit causing poor fuel mixture resulting in high cylinder temps.
bears4x4
grease monkey
katy texas
im doing the o2 sensor, fuel filter, tomorrow, its the only things i can think of that i havent done in a while
If you have an O2 forcing a lean enough condition to drive the NOx high, you're going to set a code..
did you propane it to check for vacuum leaks?
bears4x4
grease monkey
katy texas
what do you mean propane it to check for leaks, never heard of that?
You spray propane around the suspected leaking vacuum hose, and if the rpms increase, that is the leak. Fuel will cause the motor to increase in rpms, Old trick...
