Now What?
Chatolue
AZ.
I've stripped the head of a bolt on my tc inspection plate, dabnabit, whats my options now with just a little nub left on the son of a Quaker! Squirted it down with WD and tried vice grips on one of the other stubborn ones and that one popped loose but this ones stuck something good! Any suggestions before I just cut the sucker off?
zip it off with a whizzer wheel... drill it out and heli-coil it.
Tbar
SDD STAFF/Moderator
On my tractor I welded a nut to the head of the bolt (through the center of the nut) so I could get a wrench on it.
Not sure how well the sensitive electronics on your truck would react to that though.
Tbar
oi8228oi said:
try the PB bolt losener much much better then WD or that other watered down stuff.. just keep drenching it every 5 mins for about an hour and it should come right out.... good luck
I second the PB.... that's some good stuff... Mag 1 makes a real good one, too...
