No Start in Park
makuloco2000
USA
Forgot about this common issue with the Superduty and Excursion vehicle that while it won't leave you stranded, it is a pain to live with. It has to do with the shift linkage bracket bolts coming loose and losing the shift cable adjustment as a result. Check out the video, as you will likely run across this at some point in your ownership of the Superduty. I hope my video helps!
https://www.youtube.com/watch?v=FD9AhzZOCcY
