New rims and tire help needed
smokin
Springfield/Ohio
Need some help. I am thinking about getting new rims 17x10 with terra mudd grappler 33x12.50 17. Just wanting to make sure they will fit and not rub. I have a 4 inch lift on my 2001 f350 sd. If any can give me input I would appricate it. Please post or email me. Thanks
keanoknick
Big Stroker
Cowtown TEXAS
They should fit just fine, with a 4" lift you should be able to run 35"s with no problems, possibly even 36"s with the proper backspacing.
kingkevindavid
Middleboro, Ma
I had a 2000 that I ran 35x12.50x16.5's with and all I had was the 2 inch leveling kit in the front. You should be fine and might even want to consider 35's
georgetown texas
you'll be rub free with the right backspacing to much backspacing and you'll be rubbing the springs. To little and on suspension travel on tight turns you'll hit the outside edge of the inner fender. Depending on yer truck 99-04 need 4.5 inches of backspacing. 05-08 need 5 inches of backspacing.
