Need Tire Help
Alexandria, Virginia
Need Tire Help - ProComp - 33's or 35's ?
King Ranch Rims - Standard 18" 265/75/18
What is the largest tire that I can put on without doing any lift or level?
33's - 35's ????
Thanks,
Ron
Trapper77
2003 Owner
Albany Oregon
2wd or 4wd. My 03 CC 4wd I fit 35 in bfg all terrains on it with no lift and a little trimming. This is just a lariat though but should not make a difference. I get a little rubbing on the springs at full turn.
Trapper
Trapper
Thanks Trapper -
Yep - it's an 04 King Ranch CC 4x
When you say "a little trimming" - which part and where are you trimming? The KR has the lip moulding on it and I'm not looking forward to having to trim that. I can deal with a little rubbing at full turn.
Also - I am keeping the stock King Ranch rims -
Ron
ranger boy
Banned User
im guessing in the wheel well's, thats where i had to trim from rubbing
HINT: BFGoody's run 2" too big, for instance, i'm running 37"'s, but they only measure 35". You get my drift
drchris1024
SDD Security
on a river in Georgia
maybe w/ your 37" s but my 315/75/16 BFG's are 35" and my 315/70/17 BFG's are 34", I don't no how much the rim width would make a difference.
I put 315 on stock wheel on my F250 cc 4x4 and had to add a leveling kit to keep from rubbing. if you don't want to trim i'd stick w/ 285, 295, or maybe 305's...
Trapper77
2003 Owner
Albany Oregon
It rubs in the wheel well, against the liner. You can pull the liner back a little to clear. It will also catch that lower bumper plastic crap and rip it off. It is best to take a cuttoff or sawzall and cutt the corner off.
Let me know if this made any sense.
Trapper
I'm either brain dead or just plain ole confused over all of this. I've looked at so many websites - I need to learn how to drink I guess.
All I want is a tire that will fill up the hole a little better - use the stock rim and not make me hack up the truck. :confused:
Looks like it's the 18" rims that are screwing things up.
Ron
drchris1024
SDD Security
Take a look at these... Nitto Terra Grappler sizes
LT325/65 R18 121R 16.5 34.88" 12.99width 9.0-(9.5)-10.0 3195@50 596
LT325/60 R18 119S 15.6 32.99" 12.83width (9.5)-10.5 3000@65 630
LT355/65 R18 125R 16.5 36.69" 14.02width 10.0-(10.5)-11.0 3640@50 566
Thanks Chris and All -
So okay - stock tires appear to be at 32" with about 2"+/- just a tad front and back (wheels turned). Sooooo - looks like the 35s should fit.
Looking at the ProComps if'n I can get the boss to spring for that much. Heck I may have to put a little in the fund.
So since they have to be ordered - it's a best guess on the 33's or 35's. :dunno
Ron
