Need help with tire change.
Hulk
DE
So this past weekend I was airing down my tires with some automatic deflators, and I went inside for a minute but when I came out one of the deflators never cut itself off. So due to the factthat I had no compressor with me I commenced to change my tire. I found the spare tire key, the extentions for the key, but I could not find the jack. I went into the owners manuel, and it stated that the jack is under the rear bench seat in the 250 supercabs.
Long story short. I looked everywher for this damn jack, and I could not find it. If anyone knows where it may be on a 2002 f250 super cab please help me out.
if you bought it used, it ain't there.
get a ride to a local auto store, and buy a bottle jack.
patrickc
Ontario, Canada
It should be under the bottom of the rear seat on the passengers side and the bar and jack crank should be under the hood on top of the rad cradle. Under the seat their is a steel bracket that the jack normally mounts to with a wing nut.
SeventyMach1
North Carolina
OT ... u need a key?
I had a flat the other day (damned rail roads here) ... I just stuck the jacking bar (from under the hood) into the slot in the rear bumper and cranked my spare down. Maybe mine is different.
Mine is a standard cab though ... so I can't help ya' w/ the jack. I just know mine is mounted next to the rear of the cab behind the passenger seat. But yeah, the other stuff is under the hood above the radiator.
JRJ04
Houston, TX
Depending on your truck, it might not have a key. i know the lariats do, probably an option on the xlt's, and there probably is no lock at all on the xl's.
