resq229
i have a 2004 4x4 f250 superduty, it is a 5.4 gas truck with automatic. today my low fuel light came on so i pulled in a gas station, i left it running and put 20 gallons in it, i went in the station to pay for the gas and when i returned to the truck it had died, i tried to crank the truck but it would not start, as the engine turned over cranking it coughed and sputtered a few times but would not start up. im assuming the fuel pump went bad but do you folks have any other suggestions of things i should check?
i know this is a diesel site, but i figured some of you die hard ford folks may have had a 5.4 truck and may be able to point me in the right direction.
Thanks in advance for any advice you can offer.
