Mirror Control
02SilverStroke
Collin County, Texas
I recently discovered that my remote mirror control only moves the mirrors to the left and not the right. Before going to the dealer to get it repaired, is this going to be an expensive item? I rarely move the mirrors, but did a few days ago and ended up getting the right side mirror too far to the left, and had to manually move it too far to the right, then use the control to set it correctly. It's one of those repair jobs that can wait for a long time.
is it just one side ? or both...if its both then id be checking the switch.
a mirror for your truck (non-LED) is about 90 bucks <or sell> COMPLETE.
the mirror directions are controled but small motors, two of 'em...they
remind me of the motors that youd find under an old slot car (remember
those when you were a kid?)
check ebay...for a replacment (once you verify its NOT the switch or
plugs/wiring)
02SilverStroke
It's on both sides, and could be the switch. The switch will work when moving the mirrors to the left, but it's dead when I try to move them to the right. I figured it was probably the switch.
Thanks.
