Making a square hole
obonaventure
West Deptford, Gloucester County, Southern New Jer
OK This is not for my truck but I guess it could be......
I'm taking a brand new computer motherboard from a small case and putting it into an older tower case. The new motherboard has front mountable USB ports and the old case does not have the necessary square hole. So I want to make one.
I need to make a square hole in a thin piece of plastic (the front faceplate on the computer). What do you guys recommend I do to acomplish this?
My thoughts are to make the outline, drill a series of holes just inside the outline, break it out and file until it is perfect (or as close as I can get it).
The thing that needs to go in the hole fits in from behind so any imprefections would be noticable, but not the end of the world as its only a computer.
Tx_Atty
Master Baiter
Fishin'
a dremel would help with that but that is about all I can offer. They have cutting blades so you could draw the line and cut along it rather than drill.
Keller, TX
A dremel would be the easiest. If not, you might try a larger drill bit (depending on the number of USB ports). You could then "square it out" using some sandpaper.
Or, you might check the local computer store for some very small doors (hinged). Then it won't matter what the hole looks like. You could just close the cover when not in use.:dunno
Hope that helps!
John
RoyBoy
Diesel Dork
central WI
I've used the drill and file method before, probably your best bet unless you are really steady with the dremel, they can get away on you.
A good sharp file will cut the plastic out pretty quick.
pdt1081
Ohio/Michigan
If it's really thin plastic, why not just use a razor knife? As long as you can hold it steady and not let it slip past your corner.
haulin8or
Hotlanta, GA
Square hole, square bit... :sorry I would go with a Dremel tool with a cutting wheel, not a cutting bit. Cutting bits can get away from you but the wheels are easier to control. :sweet
architect-builder
Jerome, Idaho
How big is the hole? Go to Home Depot or Lowes, buy yourself a small stick of square aluminum square tubing (if they have the right size), cut a small piece off and use it for your jig with a dremel or rotozip. Chances are, you will be able to use the rest of the tubing for some other mod for your truck. They are great for mounting air tanks. :sweet
Just a thought.
Barrett
