M14 Copper Washer #65628
blueoneton
Baltimore, MD
I'm getting ready to change my oil/oil filter next week. I purchased the copper oil drain plug washers 3 to a pack (M14 part #65628) from Pep Boys. I have noticed a now and then drip from the oil drain plug. The oil drain plug is tight, should I use two washers next time or stick with one washer?
Thanks:dunno
install a fumoto valve and never worry w/ it again !
QuickOilDrainValve.com - the best way to change oil
heres the one that will fit your truck -->
FORD DIESEL - QuickOilDrainValve.com
Zookie400
I WANNA GO FAST
wallingford, CT
definatly one washer.
if you over tighten it in an attempt to stop the drip, you may strip it and have a serious oil leak coming from the plug.
if anything id go w/ a paper washer or one of the washers that has a rubber gasket.
whats to be ready with ? you have some hesitation or concern about the valve ? im sure plenty here could tell you about it
Tbar
SDD STAFF/Moderator
I put mine on after finding a leak and seeing what some grease monkey had done to my threads. Didn't want to pull the engine to replace the pan in the future so I put in the valve.
Its cheep insurance.
Tbar
Scot
Howell, MI
One more washer means one less thread in the hole and a better chance of stripping the hole.
Northeast Texas
call me the oddball :stir
but i have never changed out the crush washer
i have no leaks and NO ONE ever changes my oil for me
i use a tq wrench on the pan nut. ;tu
but if i was to change it to a quick drain i would go with the fumoto
