low oil pressure
rooferjim
springfield,ma
Truck will turn over but won't start. How ever it will start with a shot of either. I have also just replaced all glow plugs. My question is where is the oil pump located.any advice would be helpful thanks
dpantazis
#12
under the cheddar curtain
1. welcome to sdd.
2. if you are broke down critical, odti. the 911 forum.
3. it helps if your describe your truck, year, engine, Trans, any mods, etc duo we can help you.
all powerstokes need oil, oil pressure and good batteries to fire. LPOP is gear rotor design in the engine. HPOP depends on engine series.
Sent from my DROID BIONIC using Tapatalk 2
Dogman
tampa,FL
DONT USE EITHER on these motors or you will be buying a new one.
