Loud Squeel Noise Under Dash
Rick S
I have a 2001 F350 Super Crew Long Bed With the 7.3 Power Stroke Diesel. Recently while towing my 5th wheel trailer I started getting this loud squeel noise from under the dash when I reach around 65 MPH. At first I thought that it was feedback through the radio, but I disconnected the radio and I still get this noise. Some times it's louder than others but almost always it's there.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Vacume leak/whistle from the HVAC?
Blower fan motor going bad?
:dunno :dunno
It can't be the speedometer, it's electronic, no old style speedometer cable.
Rick S
Squeal Noise
I wish it were that easy, this noise is loud and if I slow down to 62 or less it goes away. Really sounds like feed back through speaker accept that it in the dash somewhere.
By the way I was a B-52/KC 135 Crew Chief for 16 years "D-G" models.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Does it happen all the time or just when you've got the 5'er in trail?
roosterdiesel
Earl needs B100
Amarillo,TX
Welcome to SDD!:sweet
Could it be a boost leak? Do you have gauges? ANy performance loss?
Once when I left the orange boots on the plenums completely loose they would sound like a high pitched squeal at high boost levels. Didn't do it at low boost levels.
Rick S
I haven't tried to see if it does it without trailer in tow. I'll check it and see.
Rick S
I checked and this happens even when not towing my trailer. I don't notice any performance issues, just this loud squeal??
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Does the squeel just start at a certain MPH? Or does it vary depending on if you have a headwind or tailwind?
Does it vary at all with vehicle speed or engine rpm, or maybe even transmission gear?
For the most part, I'm thinking air or vacume leak. :dunno :dunno
Rick S
This starts happening at 62 mph and gets louder the faster I go. It will quit when I get back below 62. It doesn't matter if there is any wind in either direction.
Rex-a-FORD
Muscatine, IA
Have you added or repositioned anything on the outside of the truck. Maybe change d or added an antenna. Anything that would affect airflow over and around the cab.
If so, you may have created an area where a harmonic could develop and create the noise your hearing. I know ya' said it was coming from under the dash, but vibration noises can be transmitted a long ways in these vehicles.
