lightning strike
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
I had a bolt of lightning hit the front end loader I was driveing down a road to a job site. :eek: It set the parking brake on and shut down all the functions. It has 35 hours on it so it is all computer controlled. It goes into a limp mode so I could drive it in 1st gear at low speed, the hydralics don't work and the wipers, driveing lites, and strobe can't be turned off. This happened on Monday and the John Deere tech Guys still haven't got it figured out yet. Anybody had a computer era car or truck hit and have any problems. O ya I'm fine but the old ears are still ringing.
WOW !!!! Hell with the JD... Glad yer OK.
Had a similer deal with a D-8 CAT w/ripper, hit an underground cable (that was'nt supposed to be there)... CAT had to, basicly, re-wire the WHOLE system(s), computer, wireing, relays, breakers..... the whole 9 yards. glad it was'nt mine to fix. If I remember correctly, about 15K (???)
John Deere
Douglas WY
Glad you are OK. :)
Have the tires gone flat yet, I have heard that lightning will put many pin holes through the tires as it reaches ground, virtually ruining the tires.
f100cleveland
Southern Minnesota
John Deere said:
Glad you are OK. :)
Tires are still up and the tech guy has replaced the main dash panel and at least one of the control box's. Nothing works yet :( . They are going to haul it to the shop and give us a loaner till its fixed. We looked for a burnt entry spot on the machine but couldn't find any. Sure wish it was working as tomorrow I was going to use it to build a compact car enduro track for our county fair. It's raining out now and they were supposed to have the truck and tractor pull tonight. I was going to enter the SD but will need some super swamper if this keeps up. :drive
kenh
Glad you wern't singed.
We had a strike here yesterday, close enough that I heard a loud SNAP/CRASH.
Sure got my attention.
Glassdude
Sonoma, CA
You didn't mention the condition of your shorts ;) I know mine would have been full. :D Glad your OK.
