lift kit
Stroke
Salinas,California
Sky manufacturing has a front shackle reversal kit That will give 3" inch's of lift. has anyone tried this lift kit for the OBS. Procomp doesnt make a lift kit for the 97 f250.
dlonno
BeerHunter
San Diego
I've heard thats easy to do and you you dont lose anything off the factory ride.
arrowstrap
BioMechanic
wa
i have a RSK for 5" front & FSK for 4.5" rear. do i need to get brake line extentions or can i just move the brake brackets to give me some more room?
Stroke
Salinas,California
Could I use Stock superduty leaf springs with the reversal shackle lift kit?
What tire size could I run with the RSK 3" lift kit?
arrowstrap
BioMechanic
wa
should be abe to use whatever springs you can use now. all it does is lower them.
heres the website where i got mine. should be able to find some info:
SKY-Manufacturing
goto the ford section on the left
arrowstrap
BioMechanic
wa
I cant remember... i think i have 34" tires. yes, factory springs. the rear flip shackle kit can be bolted to the existing hole, or welded... if you weld it you can move the bracket... i think its 1" of adjustment for 1/2" of additional lift hight. the front is all bolt on. i have the 5" kit so i can fit 37" tires. if you get the 3" kit you wont need pitman arm or brakelines
