Interesting
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
i was playin with my break out box today and i was testing the exhaust backpressure sensor. Using a spec sheet for the sensor and doing some math i was able determine any pressure i wanted just by the voltage signal..... Using my EBPV as a Exhaust Brake and turning up the idle with my AIC, i determined i was creating about 122 PSI of pressure, only at 1500 RPM and only about 4 PSI without the break on. Does this seem right, i guess i wasnt expectin to see that high of pressure
This value could be alot higher when actually using it for real breaking. I wish i had a data logger to see what it really did.
ps: i plan on doin this with the ICP too, should be able to see pressure with out a gauge, we'll see what happens-popcorn -popcorn
Neal
Dieselpwrdredneck said:
I determined i was creating about 122 PSI of pressure, only at 1500 RPM and only about 4 PSI without the break on.
I never thought it would be that high? Might be but it seems high to me.
