Aug 18, 2008 #1 H highland512 SDD Junior Member Joined Aug 3, 2008 Messages 3 Reaction score 0 Location In Can you build your own intake or is it worth the $300? If you can build your own how is it being done?
Aug 19, 2008 #2 BJS Full Access Member Joined Apr 1, 2005 Messages 1,530 Reaction score 0 Location Jacksonville, FL yes you can build your own intake you'll need: 4" diameter 6" long 45° exhaust tube 4" constant pressure band clamp (don't get a worm clamp they don't put enough pressure) Donaldson 46637 Filter you can get a filter band (keep it up off the inner fender) if desired but not required. oh and you should be able to find an intake for far cheaper, Future Home of Tymar Performance will sell you a kit that is what I described above.
Aug 19, 2008 #3 95_stroker Jefe Joined Mar 28, 2005 Messages 6,809 Reaction score 3 Location Cora, Wy Yep, I ditto what Brandon says. Welcome to SDD.
Aug 19, 2008 #4 DOC-MX FOREIGN MEMBER Joined Oct 10, 2006 Messages 168 Reaction score 0 Location Celaya, Gto, MX X3 what they said. You wont be dissapointed. Also welcome to the forum.
Aug 19, 2008 #5 Patrick Feeley Full Access Member Joined Apr 16, 2005 Messages 353 Reaction score 0 Location Tehachapi, CA I'll also vouch for the TYMAR. I built my own setup (pics in sig), but the next one I'll just purchase from Dale. No parts chasing, fitting, cutting, etc. Cheers!
Aug 20, 2008 #6 H highland512 SDD Junior Member Joined Aug 3, 2008 Messages 3 Reaction score 0 Location In Thanks for the help I'll start this project this weekend.
