Question injector cleaner
IDSTROKER
Blackfoot ID
Blackfoot ID
I was wondering if anyone has took there truck to ford and had them clean there injectors with there system. My friend took his there and he said it made a big difference but i would like more in put on this:innocent
Dogman
tampa,FL
I have, they clean the fuel real, injectors, EGR, EGR tube, and some othere things. runs about 180 bucks I think.
7.3 doesn't have an EGR.
I would be curious to find out exactly what they are claiming to do by cleaning the injectors on a 7.3.
In my opinion you're better going out and running a tank of biodiesel through the system which will dissolve any gunk in the fuel system which is doubtfully any.
when I sent my injectors in to be upgraded at 150k there were no problems with dirty injectors because I specifically asked. and FWIW there was no difference between mine and the ones that I snagged from the JY out of a totaled GA power truck either.
Dogman
tampa,FL
I would run the biodiesel first. Mine was done because they had to replace two injectors and the fuel system pretty durty. But yes in my case it made a difference.
