idi to psd swap questions
94f450sd
certified nutjob
plymouth,ma
ok i finaly have my parts truck for use as a donor truck to swap a psd into my 94 superduty.both trucks are 5 speed trucks.
but the donor truck is non-A/C and my 94 has A/C.i need a donor with A/C,dont i?or does the non-A/C trucks still have all the wiring for the A/C system?
heres the list of parts that im taking from the donor.
radiator and radiator support.
all wiring including the plug for the rear lights and fuel tanks(maybe even the whole rear wiring harness)
inner fenders with all the psd stuff for the fuse block,air filter(gonna upgrade to a tymar wanna be)
ecm and idm
possibly the fuel lines if they arent a pita to get out.
i already have the zf outta the parts truck in my 94.the rear gears are 5.13s same as my 94.
NJKen
Is a proud new daddy
central NJ
The AC can be made to work with a little additional wiring. It can be made into a stand alaone system really easilly.
Ken
Ford does not add any wires that are not needed by the vehicle, as noted by the others here.
