HPOP hoses
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I just got an Adrenaline HPOP from Dieselsite.com. My only question is about the pressure hoses going from the HPOP to the heads. How do they come off/ disconnect. I don't want to make this a situation where I learn from my mistakes. :rant
Please enlighten me.
fgtex
Little Elm, TX
Take a cheap 9/16" open end wrench and grind it down to look like this. Here , on the last page, is a link that talks about where to place the wrench. Push towards the HPOP and pull the line away from it. It sounds weird but just work it.
early 99 stroker
White Mt's NH
i found the little wrench to my dremel works perfect..slip it in give a little twist..the line pops right off..took a little messing around on the first hose to find how it works..after that it went smooth on 2 pump swaps..
Yeah.. it's a slip lock fitting like an air hose.
get new fittings from Ford if the pump doesn't have them. they're only like $15 bucks each...
