bartman said:
What are the steps for paiting the gause pod? Do you scuff up the plastic before painting? Do you use a primer? Does the paint have a "flex" additive? Any help and direction will be appreciated.
This is what dieselmanor recommends:
Gauge Mount Painting Tips
1) Prep the Gauge Mount. The first thing you need to do is remove any mold release that is left on the plastic gauge mount. This is best accomplished with an autobody wax and grease remover such as Acryli-Clean®, Prepsol®, or Pre-Cleano®. If this is unavailable, you can use denatured alcohol. Using a clean, lint-free cloth, scrub all of the areas on the Gauge Mount that are to be painted. After the degreaser has dried, scuff down the Gauge Mount with 220 grit sandpaper. All you want to do is rough up the surface to give the paint something to adhere to. Use a small circular motion and lightly sand all areas to be painted. Use this time to remove any burs that may have been left from the manufacturing process. Clean the Gauge Mount one more time with the same degreaser and allow to dry. NOTE: perform the same procedure for any plastic fasteners (nails) you wish paint as well. Only sand the tops of the fasteners, as sanding their edges will result in them becoming frayed.
2) Painting. Just prior to painting, go over the Gauge Mount with a tack cloth. This will remove any lint or dust that is remaining on the mount. Shake the can for 2 minutes after the mixing ball begins to rattle. You want to make sure the paint is well mixed before you start applying your paint. Omitting this step could cause small clumps of unmixed paint to enter the straw inside the can, resulting in a clog that you will be unable to clear. Apply 4-5 light coats of paint to the Gauge Mount, waiting 20-30 minutes between each coat. Once you are satisfied with appearance of your Gauge Mount, allow it to dry for 24 hours before you install your
gauges.
