How long would an auto last???
RoyBoy
Diesel Dork
central WI
Some of you know I've been looking for a truck, been hard to find a F-450 or 550 4X4, 7.3L, SC or CC, with a 6 speed manual. Found this one today, wondering how long it would be before I would blow the thing up towing like I do.
I was thinking I could blow the auto and then throw a 6speed in, but whaddya all think???
Thanks!
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I was thinking I could blow the auto and then throw a 6speed in, but whaddya all think??? Thanks!
There is a problem with swapping an auto tranny for a manual trans. It's the floor pan. A manual tranny is taller than an auto. You will have to do some sort of sheetmetal work to get it to work.
A better way to go that will not require butchering the interior, would be to get Brian's Truck Shop to rebuild the 4R100 tranny. A BTS automatic tranny is as tough or more so than any pickup truck 6 spd manual around. Brian has improved the 4R100 to withstand the abuse of a 700+ hp Cummins, so 300hp to 400hp from a 7.3 is no problem. No matter what you have hooked up behind you. BTS has a very good customer referal rate and history of handling warranty issues, which are fairly few and seldom. The last time I heard, BTS had two prices for doing a rebuild depending if the tranny was still in good shape or if it was a paperweight.
Another good idea would be to install a larger tranny fluid cooler for a 6.0 truck. I think the rule is for every 10*F the fluid temp is reduced, the life of the tranny is doubled.
I have had a BTS tranny for around 5 years now, and it hasn't skipped a beat yet.
platinum01
Willis, TX
Good looking truck I think it will do the job that you need it to do. I like it.
atk
Moderator
simcoe, ontario, canada
nice looking truck...i think tail guuner is right, by the time you convert to a 6-speed, you probaly could have an auto trans built by BTS....just my:2c ....
traitor.....:roflmao :roflmao :roflmao :roflmao
patrickc
Ontario, Canada
I agree with tail gunner that a properly built 4R100 will last just as long as 6 spd. (clutch and flywheel) I got 160,000 very abusive miles out of my last built 4R100. With my driving habits I doubt that I would have got that many miles out of a clutch.
roosterdiesel
Earl needs B100
Amarillo,TX
Ummmm....not knocking BTS.....but I think Roy likes to row gears and put know where his RPMs are going to be and when. He doesn't like girly trannies.:tounge
Like already stated, the floor will need fabricating. You'll also need the manual tranny PCM and wiring harness. It's been done from what I read but seems like alot of trouble to me. Find a stick truck.
Traitor?? No, he's just getting smart.:doh: J/K 6oh guys.
