How big of tires?
sambo60
fresno/CA
Hey im new to the forum and just bought a 09 f250, and i was wondering what the biggest size tire you can fit on a stock hight. It is a 4wd lariat with the offroad package. Im going to keep the 20" rims that come with the truck, so if anyone has a similar setup can you tell me what tires and sizes you are using and post pics if you can.
Thanks
sambo60
fresno/CA
I think the Lariat and off road package already has a leveling kit, does that sound about right, because the front is just as high as the rear. Sorry about the noob questions.
ponyexpress94
Diesel Power Junkie
Maryland
The 250's tend to sit fairly level from the factory. The 350's have a rake to them because of the higher payload and thus more deflection is required in the rear springs. If you have the factory 20" wheels, then the factory size tires for those wheels are approximately 34" tall so 35" tires should be no problem.
georgetown texas
well the difference is the f350 comes with a 3 inch rear block on top of the axle and the f250 comes with 1 7/8's inch block. and an extra leaf
trickyricky23r
