Helper pump and prefilter mods
02Oilburner
SDD Power Hungry
Raleigh, NC
I was wondering if anyone has this mod, and what there impressin is about it.
Better thottle response, quieter engine, ect.
Welcome to guzzle's Helper/Lift pump Web Page
Is there any retailers in Raleigh, NC that sells the Carter P4070 elec. fuel pump or is it a online item. Also what about a Dahl 2 micron filter system? Thanks again for any help guys
Tx_Atty
Master Baiter
Fishin'
let me know what you determine. I have the Racor prefilter too and have noticed what feels like a lag possibly due to flow restriction. That small pump sounds like it could be a good solution.
(If) I get around to it,adding a Carter 4070 or similar has been on my list a month now. I have a 2 micron Dahl system in front of the stock pump which I believe needs abit of a booster.
That's a nice article the fella did on the 4070 :sweet
Fire1
Certified Diesel Driver
I thought that the Dahl's were rated for Vacuum only, but I see they are rated up to 25psi. Interesting.
King0581
Monroe, VA
Just to put it out there... I've seen on other forums where people are moving the factory pump into the tank. If I would have seen it before I rounded up all the stuff for the hutch mod, I wouldve probably gave it a try.
King0581
Monroe, VA
Here is one link I found. Its been awhile since I read about it. If you do a search on that site, I think there is more info if that aint enough. Fuel pump to inside the tank. - Ford Truck Enthusiasts Forums After reading more they are not moving the factory pump but buying another pump to put in the tank, but it may be possible to install the factory pump in the tank, I'm not sure!
big bear
west plains, mo.
zoodad, fpr shimmed and the ts chip
this is big bear here and i have been reading alot of these threads. could u take time to explain to haoe to do these mods and what the benifits are from these mods. thanks: :dunno what these are:sorry big bear:rant
King0581
Monroe, VA
The helper/lift pump is added to help the factory pump after adding a prepump fuel filter(I think that was the purpose, hadnt read guzzles mod page in awhile). The guy put the pump in the tank to get rid of all air in the fuel(the factory clamps on the line leave alot to be desired). Getting rid of the air makes a more efficent and quiter running PSD!
