Hey all,
I'd like to do two mods to my 07 6.0l Lariet SD CC LB. 1st I want to add clearance lights. I've found all the info and links needed however the 2 wire connection for the lights, behind the passenger kick panel is not there. 2nd I want to add the OEM parking aid. Once again I've found all of the helpful links. The swich connection is there (behind the 4x4 selector switch) and there is a empty 14 pin connector behind the passenger kick panel with 12 wires. I believe this is for the parking aid modual. Is this correct? Also where there should be a empty connection on the back left frame rail for the sensor wiring harness there isn't one. Does the harness connect to a different spot? Or inline somewhere else? Here is the position and wire colors for the empty connector behind the passenger kick. Any help would be greatly apppreciated.
1wht/grn 2grn/wht 3blk/pink 4brn/pur 5lt blu/wht 6blk 7lt blu/pink 8blu/yel 9wht/lt blu 10pur/orange 11lt grn/yel 12brn/pink 13 empty 14 empty
Thanks,
250HUV:
Thanks,
250HUV:
