help!!! how in the he%$ do i get the exhaust pipe clamp off my turbo
bears4x4
grease monkey
katy texas
im in the proccess of removing my engine, the only thing holding be back at the moment is the dang clamp that holds the manifolds to turbo assembly wont come loose, prybar-nothing, we even hooked a 1500lb ratch strap to it and it poped off- i even grinded a hook on the end of the ratch strap and nothing, just poped off. i tried unbolting the tubing from the manifolds but 10years of heat has foided that plain, i cant even bust the bolts loose there either:dunno:dunno:dunno:dunno:dunno
when I replaced my pedestal O-rings, I had to get under it with an air chisel...
bears4x4
grease monkey
katy texas
I got it off, a long pry bar and a rubber mallot, 1 hour later. It finally came off this was the hardest part in the whole engine removal, this took the longest. man that sucked
