RocKrawler
- Joined
- Jun 24, 2006
- Messages
- 21
- Reaction score
- 0
So I'm driving down the street to get gas & light ahead turns red, downshift to let the exhaust brake help make my pads last longer & the battery light comes on, then air isnt as cold, cant steer easily & I know my belt came off. Sure enough it did, I checked the belt and it appears fine, no cracks, chunks, etc, so I figured the RPM jump when I released the clutch made it jump, only now I cant get it to go back on. I checked the manual & the tensioner is just below the alternator, says to put a wrench on it & pull up to releive tension, only in the direction it says the bolt just loosens, so how the heck am I supposed to releive tension to re-install the belt? (Manual shows putting the wrench horizontal on the pulley bolt, then lifting clockwise toward the center of the vehicle, which loosens the bolt, not lifting the pulley)
Please help - I have a buyer coming over to check it out in 2 hours!
