New Member Hello from Skiatook, OK.
RustyW
Skiatook, OK.
Hope I'm doing this right. I don't know if you are suppose to post what you own, but my current SD is a 2001 F250. I've owned a 99, 06, and a 04. I found a real clean 01 One owner it's a long bed, first one I've owned but seems like it's going to be a good one.
RustyW
Skiatook, OK.
Hey Dave Thanks, I just looked at the photos of your truck and was thinking of adding cab lights to mine. Did you just use a hole saw? and was the pillar setup hard to install?
I used a standard drill set, no hole saws required. Get the harness going down the pillar and it is an easy job. The hard part is removing the headliner. The gauges on the pillar were easy as well. I got the guage holder from someplace online and the gauges of your choice. I have Boost and EGT (Exhaust Gas Temp).
